match
Sets the match clauses. Each route map
entry has a set of match clauses used to segregate and filter packets. Packets can be
segregated using any one of the following criteria:The action taken for filtered packets is determined by the mark (action) clauses.
If no action is defined, the default is to fallback to destination-based routing for
packets satisfying the match criteria. For more information on configuring mark clauses,
see mark. And for more information on fallback action, see fallback.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
match [incoming-interface|ip|ip-access-list|wireless-client-role|wlan]
match incoming-interface [<ROUTER-IF-NAME>|pppoe1|serial <SLOT-ID> <PORT-ID>
<CHANNEL-GROUP-ID>|vlan <1-4094>|wwan1]
match ip dscp <0-63>
match ip-access-list <IP-ACCESS-LIST-NAME>
match wireless-client-role <ROLE-POLICY-NAME> <ROLE-NAME>
match wlan <WLAN-NAME>
Parameters
| incoming-interface |
Sets the incoming SVI match clause. Specify an interface name. |
| <ROUTER-IF-NAME> |
Specifies the layer 3 interface name (route interface) |
| pppoe1 |
Specifies the PPP over Ethernet interface |
<CHANNEL-GROUP-ID> |
Specifies the serial interface‘s slot, port, and
channel group IDs. |
| vlan <1-4094> |
Specifies the VLAN interface ID
- <1-4094> – Specify a VLAN ID from 1 - 4094.
| wwan1 |
Specifies the WAN interface name |
| ip dscp <0-63> |
Sets the DSCP match clause
- <0-63> – Specify
a value from 0 - 63. The defined DSCP value is used as a matching
clause for this route map.
| ip-access-list <IP-ACCESS-LIST-NAME> |
Sets the match clause using a pre-configured IP access list
- <IP-ACCESS-LIST-NAME> – Specify a pre-configured IP access list
name.
| wireless-client-role <ROLE-POLICY-NAME> <ROLE-NAME> |
Sets the wireless client role match clause
- <ROLE-POLICY-NAME> – Specify a pre-configured role policy.
- <ROLE-NAME> – Specify a pre-configured role within
it.
| wlan <WLAN-NAME> |
Sets the incoming WLAN match clause
- <WLAN-NAME> –
Specify a WLAN name.
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#match incoming-interface pppoe1
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#show context
route-map 1
default-next-hop wwan1
mark ip dscp 7
